Rack supports equipment's redundancy
Provisioning match recommendations
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA: Capacity
  • Provisioning match recommendations
  • Rack supports equipment's redundancy
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to Provisioning match recommendations
  • Mark as Read
Picard EcoStruxureIT
‎2019-10-02 02:31 AM
This status message notifies you if the redundancy of the selected equipment adheres to the redundancy of the selected rack.
The redundancy planned for the rack supports adding the selected equipment.
The rack allows for better redundancy utilization than the selected equipment is designed for.
If you add the selected equipment to this rack, you will not be utilizing the available redundancy to the optimum.
The selected equipment requires better redundancy setup than is available according to the redundancy setup for the rack.
You may need to select a different piece of equipment requiring less redundancy and add to this rack.
See also
Enabling provisioning match recommendations
