Available fiber-based network ports
Provisioning match recommendations
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA: Capacity
  • Provisioning match recommendations
  • Available fiber-based network ports
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to Provisioning match recommendations
  • Mark as Read
Picard EcoStruxureIT
‎2019-10-02 07:05 AM
This status message notifies you if there is a sufficient amount of fiber-based network ports available for the selected equipment in the selected rack.
There is a sufficient amount of available fiber ports to support the network requirements of the selected equipment.
There are available fiber ports to support some of the network requirements of the selected equipment but the amount of available ports is insufficient.
There are no available fiber ports to support the network requirements of the selected equipment.
Note: If you use the network type: other, the placement recommendations may not be reliable since the advisor does not support network port types that are not defined as either fiber or copper.
See also
Enabling provisioning match recommendations
