Rack PDU supports equipment's load
Provisioning match recommendations
Send InviteCancel
This status message notifies you if the connected rack PDU is capable of supplying the power needed by the equipment.
The rack PDU supports the needed power supply to the selected equipment.
The rack PDU does not support the needed power supply to the selected equipment. You may need to select another rack PDU or equipment, or change the breaker settings if these are incorrect, to keep within the physical boundaries of the rack PDU breaker.
