Serial Device Settings option
NetBotz Appliance configuration settings in DCE
  • EcoStruxure IT Help Center
  • Monitoring NetBotz Appliances in DCE
  • NetBotz Appliance configuration settings in DCE
  • Serial Device Settings option
  • Mark as Read
  • Using the NetBotz Appliance Configuration options
  • User Settings option
  • SNMP Settings option
  • SMS Settings option
  • Results display
  • Region Settings option
  • Post Alert Data Settings option
  • NetBotz Appliance Configuration (Device menu)
  • Location Settings option
  • Clock Settings option
  • Camera Settings option
  • Backup/Restore option for NetBotz appliances
  • Results display
EcoStruxure IT Support
Request Support
Back to NetBotz Appliance configuration settings in DCE
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:14 AM
Use this option's configuration display to identify the Port Label for each serial port at the selected NetBotz Appliance, and the devices that connect to those ports.
You can select Remove to delete a port's device reference when the device is disconnected from the NetBotz Appliance.
