Location Settings option
NetBotz Appliance configuration settings in DCE
  • EcoStruxure IT Help Center
  • Monitoring NetBotz Appliances in DCE
  • NetBotz Appliance configuration settings in DCE
  • Location Settings option
  • Mark as Read
  • Using the NetBotz Appliance Configuration options
  • User Settings option
  • Serial Device Settings option
  • SNMP Settings option
  • SMS Settings option
  • Results display
  • Region Settings option
  • Post Alert Data Settings option
  • NetBotz Appliance Configuration (Device menu)
  • Clock Settings option
  • Camera Settings option
  • Backup/Restore option for NetBotz appliances
  • Results display
EcoStruxure IT Support
Request Support
Back to NetBotz Appliance configuration settings in DCE
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:14 AM
Use the configuration display in this option to edit the location settings at the selected NetBotz Appliance or Appliances.
Elements Description
Pod/Sensors Allows you to select a listed device or sensor for which you want to edit the Location Data.
When a single appliance is selected, the list has the following entries:
  • NetBotz Appliance
  • Sensor pods
  • Output relay pods
  • Camera pods, with individual sensors
  • Ethernet link status
When multiple appliances are selected, this list provides the following entries, only:
  • NetBotz Appliances
  • Sensor pods
  • Camera pods, without individual sensors
    Note
    No listing is provided for output relay pods, or Ethernet link status.
Location Data Allows you to select the value you want to edit from a wide variety of standard, location-based values.
Note
By default, pods, and the Ethernet link status, inherit their NetBotz Appliance settings, and sensors inherit their pod's settings.
Edit Click to edit a selected location value.
