Clock Settings option
NetBotz Appliance configuration settings in DCE
  • EcoStruxure IT Help Center
  • Monitoring NetBotz Appliances in DCE
  • NetBotz Appliance configuration settings in DCE
  • Clock Settings option
  • Mark as Read
  • Using the NetBotz Appliance Configuration options
  • User Settings option
  • Serial Device Settings option
  • SNMP Settings option
  • SMS Settings option
  • Results display
  • Region Settings option
  • Post Alert Data Settings option
  • NetBotz Appliance Configuration (Device menu)
  • Location Settings option
  • Camera Settings option
  • Backup/Restore option for NetBotz appliances
  • Results display
EcoStruxure IT Support
Request Support
Back to NetBotz Appliance configuration settings in DCE
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:13 AM
Edit the date and time settings at the selected NetBotz Appliance or Appliances, or to synchronize the settings with the date and time at an NTP server.
Element Description
Enable NTP Server When selected, a Network Time Protocol (NTP) server provides the date and time values at a selected appliance; otherwise, these values are defined by the other Date and Time elements.
NTP Server 1 - 3 Identify the IP address or hostname of at least one NTP server, when Enable NTP Server is selected.
Use Server Time Click to use the Data Center Expert server's time and date settings at a selected appliance, when Enable NTP Server is not selected.
Date Define the date a selected appliance will use, when Enable NTP Server is not selected.
Time Define the time a selected appliance will use, when Enable NTP Server is not selected.
Calendar Displays the date currently defined at a selected appliance, and can be used to define that date, when Enable NTP Server is not selected.
