Backup/Restore option for NetBotz appliances
NetBotz Appliance configuration settings in DCE
Send InviteCancel
Use this option to store a configuration backup file in the server database for a selected NetBotz Appliance or Appliances, or to use those backup files to restore selected NetBotz Appliance configurations.
The "Backup/Restore" wizard has three displays, two of which are shared with other NetBotz Appliance Configuration options, and a password pop-up display.
Use the "Select Backup or Restore" display to select whether you want to backup or restore NetBotz Appliances.
Use the "Select NetBotz Appliance" display, which is shared with every NetBotz Appliance Configuration option except Camera Settings, to select the appliances you want to backup or restore.
Use the "Backup/Restore Password" pop-up display to define a password used to encrypt backup configurations, or to access the backup files used to restore configurations.
Note
If you use an invalid password during an attempt to restore a NetBotz Appliance in Post-only Mode, the restore will not occur, and no error will be reported. You will need to repeat the restore procedure using the valid password.
Use the shared "Results" display to view the results of the backup or restore activity.
