User Settings option
NetBotz Appliance configuration settings in DCE
  • EcoStruxure IT Help Center
  • Monitoring NetBotz Appliances in DCE
  • NetBotz Appliance configuration settings in DCE
  • User Settings option
  • Mark as Read
  • Using the NetBotz Appliance Configuration options
  • Serial Device Settings option
  • SNMP Settings option
  • SMS Settings option
  • Results display
  • Region Settings option
  • Post Alert Data Settings option
  • NetBotz Appliance Configuration (Device menu)
  • Location Settings option
  • Clock Settings option
  • Camera Settings option
  • Backup/Restore option for NetBotz appliances
  • Results display
EcoStruxure IT Support
Request Support
Back to NetBotz Appliance configuration settings in DCE
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:15 AM
Use this option's configuration display to manage the users at the selected NetBotz Appliance or Appliances, as well as to select the severity of logon failures, and the alert profile used for the alert notifications for those failures.
Users
A Users list identifies the users by Name, Username, and Privilege Set., and Add, Edit, and Delete buttons allow you to manage that list.
The "Add User" and "Edit User" displays have standard account Name and logon values (Username, Password, and Verify Password). They also have a Privilege Set drop-down menu used to select the access a user will have at the selected NetBotz Appliances.
Note
You cannot delete the Guest Account, and can only edit its Privilege Set; you can edit the Name, Username, and Password values for the default administrator, but you cannot delete it, or change its Privilege Set.
Privilege Description
None Allows no access to any features.
Administrator Allows access to all information and configuration tasks at a selected appliance.
Sensor (No camera) Allows access to the Navigation pane, Sensor Data pane, Map View (if enabled), and selected portions of the NetBotz Advanced View information and action views, as well as the ability to view the Graphs View and About view.
This Privilege Set does not allow access to the Cameras View, Alerts View, or Configuration view.
Sensor In addition to Sensor (No Camera) access, allows access to the Cameras View.
This Privilege Set does not permit access to the Alerts View or Configuration view.
Application Allows access to the Navigation pane, Sensor Data pane, Map View (if enabled), and selected portions of the NetBotz Advanced View information and action views. Also allows viewing the Camera View, Graphs View, Alerts View, and About view.
This Privilege Set does not permit access to the Configuration view, or the ability to resolve alert conditions for thresholds configured with the Return-To-Normal Requires User Input setting selected for their Advanced Settings.
Application (with Alert Update)
In addition to Application access, allows the ability to resolve alert conditions for thresholds configured with the Return-To-Normal Requires User Input setting selected for their Advanced Settings.
This Privilege Set does not permit access to the Configuration view.
Logon alerting
Provides two drop-down menus, one which selects the alert profile you want a selected NetBotz Appliance (greyed out when multiple appliances are selected) to use for alert notifications for logon failures, and one which selects the severity you want assigned to logon failures at the selected appliance or appliances: Informational, Warning, Error, Critical, and Failure.
Note
Default, for Logon Failure Alert Profile, and Failure, for Logon Failure Alert Severity, are the default settings.
