Using the NetBotz Appliance Configuration options
NetBotz Appliance configuration settings in DCE
Send InviteCancel
The NetBotz Appliance Configuration options all use the same basic configuration procedure, with the exception of Backup/Restore and Camera Settings, Rack Access Settings, and the Alert Settings options.
Note
For information about the Alert Settings and Rack Access Settings options, use the related links to the help for these options.
In the Device menu, select a NetBotz Appliance Configuration option other than Backup/Restore or Camera Settings.
Note
For information about the Backup/Restore and Camera Settings options, use the related links to the help for these options.
In the "Select NetBotz Appliance" display, select the NetBotz Appliance or Appliances you want to configure, and click Next.
Note
The Serial Device Settings, SMS Settings, and Pod Sharing Settings options allow you to configure only one appliance at a time.
In the settings display, configure the settings you want the selected NetBotz Appliance or Appliances to use, and click Next.
In the "Results" display, review the configuration results, and click Finish when no NetBotz Appliance is reporting that its configuration is still In Progress.
Note
For information about the possible status results, see Results display.
