Post Alert Data Settings option
NetBotz Appliance configuration settings in DCE
  • EcoStruxure IT Help Center
  • Monitoring NetBotz Appliances in DCE
  • NetBotz Appliance configuration settings in DCE
  • Post Alert Data Settings option
  • Mark as Read
  • Using the NetBotz Appliance Configuration options
  • User Settings option
  • Serial Device Settings option
  • SNMP Settings option
  • SMS Settings option
  • Results display
  • Region Settings option
  • NetBotz Appliance Configuration (Device menu)
  • Location Settings option
  • Clock Settings option
  • Camera Settings option
  • Backup/Restore option for NetBotz appliances
  • Results display
EcoStruxure IT Support
Request Support
Back to NetBotz Appliance configuration settings in DCE
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:14 AM
Use this option's configuration display to identify the IP or address you want the NetBotz Appliances monitored by your server to send their alert data.
When a NetBotz Appliance is discovered by Data Center Expert, the hostname of the Data Center Expert is added to the NetBotz Appliance. This enabled the Data Center Expert to receive alert postings from the NetBotz Appliance. If your server does not use DNS, you will need to change the alert post entry on the NetBotz Appliance to the IP Address of the Data Center Expert server.
Note
This display also can be accessed when using Network Settings, a Server Administration Settings option in the System menu, to change the Public (LAN1) tab's Hostname or IP Address settings: when asked if you want to update the NetBotz Appliance post settings, click Yes.
Element Description
Current Data Center Expert Hostname The Hostname defined in the Network Settings option's Public (LAN1) tab.
Current Data Center Expert IP Address The IP Address defined in the Network Settings option's Public (LAN1) tab.
Select the Address to Use for Sending Alert Data Select an IP address or hostname from the drop-down list, or type in the hostname or IP address you want the monitored NetBotz Appliances to use to post alert data.
Note
If any of the NetBotz Appliances you want the Data Center Expert server to monitor have no DNS service available, select to use the server's IP address. Otherwise, those appliances will be unable to post data to the server, and status will only be available in response to polling.
