SNMP Settings option
NetBotz Appliance configuration settings in DCE
  • EcoStruxure IT Help Center
  • Monitoring NetBotz Appliances in DCE
  • NetBotz Appliance configuration settings in DCE
  • SNMP Settings option
  • Mark as Read
  • Using the NetBotz Appliance Configuration options
  • User Settings option
  • Serial Device Settings option
  • SMS Settings option
  • Results display
  • Region Settings option
  • Post Alert Data Settings option
  • NetBotz Appliance Configuration (Device menu)
  • Location Settings option
  • Clock Settings option
  • Camera Settings option
  • Backup/Restore option for NetBotz appliances
  • Results display
EcoStruxure IT Support
Request Support
Back to NetBotz Appliance configuration settings in DCE
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:15 AM
Use this option's configuration display to configure the Simple Network Management Protocol (SNMP) settings the selected NetBotz Appliance or Appliances can use to communicate with an SNMP-based Network Management Server (NMS).
Note
Enable SNMP Agent must be selected to configure the settings.
Version 1/Version 2c tab
Use this tab to define the settings an NMS can use for SNMPv1 or SNMPv2c communication with a NetBotz Appliance.
Element Description
Enable SNMP Agent Select to enable the SNMP agent settings.
Read-only Community Name Define the community name used for read-only SNMP requests.
Confirm Name Confirm a new or edited Read-only Community Name definition.
Read/Write Community Name Define the community name used for read and write SNMP requests.
Confirm Name Confirm a new or changed Read/Write Community Name definition.
Port Identify the number of the port used for SNMP agent communication.
Version 3 tab
Use this tab to identify the settings that an NMS can use for SNMPv3 communication with a NetBotz Appliance.
Element Description
Users Select the user accounts an NMS can use to connect to the SNMPV3 Agent on a selected NetBotz Appliance.
Authentication Protocol Select SHA-1 or MD5 as the protocol used when sending SNMPv3 informs to the target device.
Encryption Algorithm Select whether encryption will be used with the SNMPv3, and if used, which protocol: None, DES, or AES-128.
