NetBotz Appliance Configuration (Device menu)
NetBotz Appliance configuration settings in DCE
  • EcoStruxure IT Help Center
  • Monitoring NetBotz Appliances in DCE
  • NetBotz Appliance configuration settings in DCE
  • NetBotz Appliance Configuration (Device menu)
  • Mark as Read
  • Using the NetBotz Appliance Configuration options
  • User Settings option
  • Serial Device Settings option
  • SNMP Settings option
  • SMS Settings option
  • Results display
  • Region Settings option
  • Post Alert Data Settings option
  • Location Settings option
  • Clock Settings option
  • Camera Settings option
  • Backup/Restore option for NetBotz appliances
  • Results display
EcoStruxure IT Support
Request Support
Back to NetBotz Appliance configuration settings in DCE
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:13 AM
The configuration settings at the monitored NetBotz Appliances can be defined using the NetBotz Appliance Configuration options, or by using the NetBotz Advanced View at each appliance. NetBotz Appliance Configuration options allow you to modify those configuration settings, as needed.
Note
Only model 5xx NetBotz Appliances support all the NetBotz Appliance Configuration options without any additional software modules. For information about whether a specific model 3xx or 4xx appliance can be configured using a NetBotz Appliance Configuration option, access the NetBotz Advanced View for that appliance.
The Data Center Expert server can notify users when the Data Center Expert server alarm thresholds are triggered for its monitored devices. Additionally, the Alert Settings options in the NetBotz Appliance Configuration option define how the monitored NetBotz Appliances can each generate their own alert notifications in response to alert threshold violations that occur at the devices they monitor.
With the exception of the Camera Settings, Serial Device Settings, SMS Settings, and Pod Sharing Settings options, the NetBotz Appliance Configuration options can be used to configure the settings at multiple appliances at the same time, using the same settings at each. To configure Rack Access Settings at multiple appliances, you must select the NetBotz Appliances, then select that NetBotz Appliance Configuration option.
Note
With the exception of the Alert Settings and Post Alert Data Settings options, any of these configuration options can be accessed using right-click NetBotz Appliance Configuration options in the Device View, Map View, and Device Groups view; a single right-click option, NetBotz Appliance Camera Settings, is available in the Thumbnails view to access the Camera Settings.
