ITA SNMP status codes
External system integration (on premises only)
Send InviteCancel
In IT Advisor, the IT Advisor server supports these SNMP OIDs and response values.
To implement the alarm statuses in Data Center Expert, update the Device Definition File, schneiderops.xml, in Data Center Expert. Download the file from the software download link provided by Schneider Electric and follow the instructions about updating DDFs in DCE.
Application server (OID .1.3.6.1.4.1.318.1.2.2.1.1.0)
Response
Name
Description
1
Unknown
The status of the application server is unknown. Check Webmin and if the problem persists, contact support.
2
Stopped
Restart the IT Advisor server. If the problem persists, contact support.
3
Running
No problem
4
Running but missing nodes
High availability is lost. The IT Advisor Application server is running but one or more nodes are not available. If the problem persists, contact support.
5
Initializing
Wait for the IT Advisor Application server to initialize. If the problem persists, contact support.
6
Starting or non responding
Wait for the IT Advisor Application server to finish starting. If the problem persists, contact support.
7
Disaster Recovery
This node is running in DR mode.
8
Running but postoffice is inconsistent
The JBoss postoffice is currently inconsistent. This may be a temporary issue. If the problem persists for more than 10 minutes, contact support.
9
Running but missing jgroups
The JBoss is missing jgroups. This may be a temporary issue. If the problem persists for more than 10 minutes, contact support.
Database server (OID .1.3.6.1.4.1.318.1.2.2.1.2.0)
Response
Name
Description
1
Unknown
The status of the database is unknown. Check Webmin and if the problem persists, contact support.
2
Stopped
3
Running
No problem
4
Detached
High availability is lost. If the problem persists, contact support.
5
Catching up
Wait for the IT Advisor database to retrieve all updates from the master node. If the problem persists, contact support.
10
Running alone
The database does not replicate its changes to other nodes.
Load balancer (OID .1.3.6.1.4.1.318.1.2.2.1.3.0)
Response
Name
Description
1
Unknown
Load Balancer status is unknown. Check Webmin and if the problem persists, contact support.
2
Stopped
Load Balancer stopped. Restart the IT Advisor server. If the problem persists, contact support.
3
Running
Normal status
4
High availability is lost. The IT Advisor Load Balancer is running but one or more nodes are not available. If the problem persists, contact support.
General and essential services (OID .1.3.6.1.4.1.318.1.2.2.1.4.0)
Response
Name
Description
1
Unknown
Unknown status. Check Webmin and if the problem persists, contact support.
2
Stopped
Essential services are not running on the IT Advisor server. Reboot the node and monitor the status page in Webmin. If the problem persists, contact support.
3
Running
Normal status
5
Backup failed
The last backup that was attempted on this server was not successful. Ensure the system can write to the location specified as backup location. This is particularly relevant for network attached storage.
ETL (OID .1.3.6.1.4.1.318.1.2.2.1.5.0)
Response
Name
Description
1
Unknown
2
OK
Normal status
3
Error
ETL experienced an error while running the transformation. Monitor the status page in Webmin. The scheduler will try to run the transformation again as scheduled.
4
Paused
ETL is paused on the IT Advisor server. Monitor the ETL status page in Webmin. Try to start the job if needed using the management button.
