Configuring external system integration
External system integration (on premises only)
Send InviteCancel
In System Setup > External System Configuration, you can set up integration with an external system. Select the type of server, for example, Data Center Expert or VMware vCenter server, and enter the server communication data.
The latest version of the integration software is supported unless any issues with the latest versions are specified in the release notes for your ITA version.
Once the communication between the servers has been established, the IT Advisor server retrieves alarms and measured data from the external monitoring system or migration data from the virtualization system. When you have configured the physical location of these real-world devices, the system can guide you and show any active and potential problem areas in your data center.
Alarms and migration data is collected in real time and allows you to monitor and react instantly on critical data.
