HP OneView integration
External system integration (on premises only)
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA installation and setup
  • External system integration (on premises only)
  • HP OneView integration
  • Mark as Read
  • Configuring external system integration
  • Configuring Data Center Expert integration
  • Configuring Power Monitoring Expert integration
  • Cisco UCS Manager integration requirements
  • Configuring Cisco UCS Manager integration
  • RF Code CenterScape Connector
  • Configuring VMware vCenter integration
  • ServiceNow Asset Management Connector
  • ServiceNow Change Management Integration
  • ITA SNMP status codes
EcoStruxure IT Support
Request Support
Back to External system integration (on premises only)
  • Mark as Read
Picard EcoStruxureIT
‎2019-10-14 08:34 AM
Available for IT Advisor on-premise installations only
The HP OneView integration is available with the standard ITA license. This allows you to get basic server and blade enclosure information from the HP OneView system.
With the Data Center: IT Optimize license, you also get CPU and power data from the HP OneView system.
Assets and alarms are transferred instantly from HP to ITA using an event bus. CPU, power and temperature data are polled from the HP OneView system using its web service interface.
The data shown when you hover over a tool tip is also loaded instantly from the HP OneView server.
ITA also presents historical trending (calculated average over the last 7 days). The interval for polling data for this trending can be configured (System Setup > External System Configuration > HP OneView Configuration > Utilization update interval in hours), but the default setting should be precise enough.
No data is transferred from ITA to the HP system.
123 Steps to...
Configuring data exchange between HP OneView and IT Advisor
  1. In System Setup > External System Configuration, click Add server and select HP OneView.
  2. Set up the connection to HP OneView using the credentials of the HP OneView user (user must be HP Oneview administrator) (Figure 1) and click Test to validate the server connection.
  3. Edit update interval (Figure 2).
  4. Open Planning>Device Association from the application bar.
  5. Drag devices discovered by HP OneView from Unassociated Devices to equipment representing them in the floor or in the rack layout to associate them.
Figure 1
Figure 2
100% helpful (1/1)
