Cisco UCS Manager integration requirements
External system integration (on premises only)
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA installation and setup
  • External system integration (on premises only)
  • Cisco UCS Manager integration requirements
  • Mark as Read
  • Configuring external system integration
  • Configuring Data Center Expert integration
  • Configuring Power Monitoring Expert integration
  • Configuring Cisco UCS Manager integration
  • RF Code CenterScape Connector
  • HP OneView integration
  • Configuring VMware vCenter integration
  • ServiceNow Asset Management Connector
  • ServiceNow Change Management Integration
  • ITA SNMP status codes
EcoStruxure IT Support
Request Support
Back to External system integration (on premises only)
  • Mark as Read
Picard EcoStruxureIT
‎2019-10-14 08:34 AM
Last Updated: Sisko JLehr Sisko ‎2024-03-18 08:04 AM
For ITA on-premise installations only
Configuring integration between IT Advisor and Cisco UCS Manager requires:
  • A user has been set up on the Cisco UCS Manager with rights to access the web services in the API.
  • Communication on the port used on the Cisco UCS Manager and, if SSL is wanted, it must be enabled.
Default ports:
http: 80
https: 443
The rest of the configuration happens on the Cisco UCS Manager.
For further information, see Cisco UCS Manager API information and power management.
