Configuring VMware vCenter integration
External system integration (on premises only)
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA installation and setup
  • External system integration (on premises only)
  • Configuring VMware vCenter integration
  • Mark as Read
  • Configuring external system integration
  • Configuring Data Center Expert integration
  • Configuring Power Monitoring Expert integration
  • Cisco UCS Manager integration requirements
  • Configuring Cisco UCS Manager integration
  • RF Code CenterScape Connector
  • HP OneView integration
  • ServiceNow Asset Management Connector
  • ServiceNow Change Management Integration
  • ITA SNMP status codes
EcoStruxure IT Support
Request Support
Back to External system integration (on premises only)
  • Mark as Read
Picard EcoStruxureIT
‎2019-10-14 08:34 AM
For IT Advisor on-premise installations only
Configure the server communication preferences between IT Advisor and VMware vCenter Server. See supported versions here.
The VMware vCenter user must have permission to these operations:
  • setCustomValue
  • logUserEvent
  • setTaskDescription
  • addCustomFieldDef
  • exitMaintenanceModeTask
  • destroyPropertyFilter
  • createFilter
  • waitForUpdatesEx
  • retrieveServiceContent
  • login
  • logout
  • waitForUpdates
  • retrieveProperties
  1. Type the logon information of the vCenter server to connect to: host name / IP address, port number, and user credentials.
  2. For a high-security logon session, select Use SSL and accept the certificate.
    Ask the vCenter Server administrator for details if you are unsure whether to use SSL.
The VMware vCenter integration is event-based meaning the vCenter will report directly to IT Advisor if events/updates occur that the system must be notified about.
Comments
jlales
jlales Cadet
Cadet
  • Mark as Read
‎2025-02-21 09:02 AM
What versions of VCenter are supported?
