Configuring Cisco UCS Manager integration
External system integration (on premises only)
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA installation and setup
  • External system integration (on premises only)
  • Configuring Cisco UCS Manager integration
  • Mark as Read
  • Configuring external system integration
  • Configuring Data Center Expert integration
  • Configuring Power Monitoring Expert integration
  • Cisco UCS Manager integration requirements
  • RF Code CenterScape Connector
  • HP OneView integration
  • Configuring VMware vCenter integration
  • ServiceNow Asset Management Connector
  • ServiceNow Change Management Integration
  • ITA SNMP status codes
EcoStruxure IT Support
Request Support
Back to External system integration (on premises only)
  • Mark as Read
Picard EcoStruxureIT
‎2019-10-14 08:34 AM
Last Updated: Sisko JLehr Sisko ‎2024-03-18 08:01 AM
For ITA on-premise installations only
Configure the server communication preferences between IT Advisor and the Cisco UCS Manager.
  1. Configure data retrieval from Cisco UCS Manager to IT Advisor.
    • Type the logon information of the Cisco UCS Manager to connect to: host name / IP address, port number, and user credentials.
    • For a high-security logon session, select Use SSL and accept the certificate.
      Ask the Cisco UCS Manager administrator for details if you are unsure whether to use SSL.
    • Click Test to test the connection.
  2. Configure data exchange from IT Advisor back to Cisco.
    • Select Use Automatic Power Management if you want to allow IT Advisor to send back power data to Cisco.
      This will overwrite any existing power groups on the Cisco UCS Manager.
See also
Viewing External System Data
The Importance of System Time Synchronization for Accurate Power Values
