Adding or updating device definition files (DDFs) for SNMP devices
DCE device configuration
  • EcoStruxure IT Help Center
  • DCE configuration
  • DCE device configuration
  • Adding or updating device definition files (DDFs) for SNMP devices
  • Mark as Read
  • Status messages: Device Configuration Status view
  • Retrieving device settings in the APC SNMP Device ...
  • Modify Device Settings display for Modbus
  • Edit Device Scan Settings display for Modbus
  • Device File Transfer Settings display
  • Copy Register Map to Devices display
  • Configure Device Settings display
  • Building Management Settings display for Modbus
  • Adding or updating device definition files (DDFs) ...
  • APC SNMP Device Configuration wizard results
  • APC SNMP Device Configuration (Device menu) v7.3.x...
EcoStruxure IT Support
Request Support
Back to DCE device configuration
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:12 AM
Use the "Add/Update Definitions" wizard to add or update the DDFs available for the SNMP devices supported by the server. The new or updated DDFs can be uploaded to the server from a local file, or from the APC website.
  1. Select Device Definition Files, an SNMP Device Communication Settings option in the Device menu.
  2. Select the Device Definition Files option in the "SNMP Device Communication Settings" display.
  3. Click Add/Update Definitions in the Device Definition Files tab.
  4. In the "Select Update Method" display, select the option you want to use to add or update DDFs, and follow the appropriate instructions.
    • To use files from APC, see step 5.
    • To use files previously downloaded to a local computer, see step 6.
  5. To download files from APC, do the following.
    1. Select Check APC Website and click Next.
    2. In the "Select DDF Files" display, select the files you want to download, click Next, and go to step 7.
  6. To use a local file, do the following.
    1. Select Local File and click Browse.
    2. In the "Open" display, navigate to the file you want to use, and double-click that file (or click it once, and then click Open).
    3. In the "Select Update Method" display, verify the correct file is identified, click Next, and go to step 7.
  7. In the "Installed/Updated DDF Files" display, verify the files you selected are listed, and click Finish, to exit the wizard, or Back, to return to the "Select Update Method" display.
