Device File Transfer Settings display
DCE device configuration
  • EcoStruxure IT Help Center
  • DCE configuration
  • DCE device configuration
  • Device File Transfer Settings display
  • Mark as Read
  • Status messages: Device Configuration Status view
  • Retrieving device settings in the APC SNMP Device ...
  • Modify Device Settings display for Modbus
  • Edit Device Scan Settings display for Modbus
  • Copy Register Map to Devices display
  • Configure Device Settings display
  • Building Management Settings display for Modbus
  • Adding or updating device definition files (DDFs) ...
  • APC SNMP Device Configuration wizard results
  • APC SNMP Device Configuration (Device menu) v7.3.x...
EcoStruxure IT Support
Request Support
Back to DCE device configuration
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:12 AM
Manage the File Transfer Protocol (FTP) or Secure Copy (SCP) access values for APC SNMPv1 and SNMPv3 devices.
Keep the access list up to date to comply with the latest cybersecurity requirements.
See New cybersecurity requirements in NMC3
Note: Functionally identical versions of this display are used by the "SNMPv1/SNMPv3 Device Discovery," "Apply Firmware Updates," and "APC SNMP Device Configuration" wizards, as well as by Device File Transfer Settings, an SNMP Device Communication Settings option in the Device menu. A change saved in one display is reflected in all.
To use FTP for APC SNMP device access, FTP server access must be enabled at that device.
To use SCP for APC SNMP device access, Secure Shell version 2 (SSHv2) console access must be enabled at that device.
Element Description
List Lists the access settings the Data Center Expert server can use for FTP or SCP access to its monitored devices.
Username: The username used for access to a device.
Note
By default, the Data Center Expert server can download firmware via FTP only to devices that use apc (lowercase) for the username and password. The credentials used for device access are identified in the "Edit Device File Transfer Settings" display.
IP or IP Range: The IP address, or range of addresses, at which the access settings support FTP or SCP communication.
FTP Port: The port used for FTP access to a device.
SCP Port: The port used for SCP access to a device.
Timeout: How long the server will wait before it considers that an attempt to access a device has failed.
Retry Limit: How many times the server will try to access a device, after the initial attempt failed, before it stops trying to access that device (1, by default).
Protocol: The protocol the transfer settings set will use to access devices (FTP only, SCP only, or Try SCP, fall back to FTP).
Add Click to add an access setting to the list.
Edit Click to edit a selected access setting.
Remove Click to delete a selected access setting.
