Building Management Settings display for Modbus
DCE device configuration
  • EcoStruxure IT Help Center
  • DCE configuration
  • DCE device configuration
  • Building Management Settings display for Modbus
  • Mark as Read
  • Status messages: Device Configuration Status view
  • Retrieving device settings in the APC SNMP Device ...
  • Modify Device Settings display for Modbus
  • Edit Device Scan Settings display for Modbus
  • Device File Transfer Settings display
  • Copy Register Map to Devices display
  • Configure Device Settings display
  • Adding or updating device definition files (DDFs) ...
  • APC SNMP Device Configuration wizard results
  • APC SNMP Device Configuration (Device menu) v7.3.x...
EcoStruxure IT Support
Request Support
Back to DCE device configuration
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:12 AM
Last Updated: Sisko JLehr Sisko ‎2025-02-28 07:39 AM
Manage the server addresses assigned to monitored devices, and to access the "Modify Device Settings" display used to map the registers assigned to sensors at a selected device.
Note: Until the MODBUS TCP Output Module license is purchased and added to the Data Center Expert server using License Keys, a Server Administration Settings option in the System menu, the "Building Management Settings" display provides only an Add License Key button you can click to access the License Keys option.
More information about the MODBUS TCP Output Module support
You can assign unique server addresses for up to 247 monitored devices; you can modify the settings for one device at a time, including the Register values for any or all of its sensors.
Element Description
Filter Filter the table to list only entries that include the text you type, exactly as typed.
List Select one or more devices, to generate or remove server identifications (Server Address), or select a single device, to modify the device settings for its sensors.
You can click on any column head (Server Address, Hostname, Parent Device, Location, Device Type, or Model) to sort the list.
Note
All monitored devices are listed, unless filtered, but only a maximum of 247 devices can have server addresses assigned.
Select/Deselect All Select (check-mark) or deselect all devices.
Modify Device Settings Click to access the "Modify Device Settings" display for a selected device.
Note
Disabled when more than one device is selected.
Generate Server IDs Click to assign a Server Address to a selected device or devices.
Note
Any device with an existing Server Address assignment will be unaffected.
Remove Server IDs Click to unassign a Server Address for a selected device or devices.
