Configure Device Settings display
DCE device configuration
  • EcoStruxure IT Help Center
  • DCE configuration
  • DCE device configuration
  • Configure Device Settings display
  • Mark as Read
  • Status messages: Device Configuration Status view
  • Retrieving device settings in the APC SNMP Device ...
  • Modify Device Settings display for Modbus
  • Edit Device Scan Settings display for Modbus
  • Device File Transfer Settings display
  • Copy Register Map to Devices display
  • Building Management Settings display for Modbus
  • Adding or updating device definition files (DDFs) ...
  • APC SNMP Device Configuration wizard results
  • APC SNMP Device Configuration (Device menu) v7.3.x...
EcoStruxure IT Support
Request Support
Back to DCE device configuration
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:12 AM
Use this "APC SNMP Device Configuration" wizard display to select, edit, and apply the settings for the configuration source selected in the "Select Configuration Source" display, at the APC SNMP devices selected in the "Select Destination Devices" display.
Typically, this display lists only the configuration source settings that can be used at all the selected destination devices: the Show Shared Settings Only is selected (check-marked).
If you disable Show Shared Settings Only, all the configuration source settings are listed and identified as follows:
Note
If no source settings can be used at all of the selected destination devices, Show Shared Settings Only is disabled, by default.
  • Black text identifies a settings category that has only settings that can be shared with all the destination devices, as well as individual settings that can be shared.
  • Brown text identifies a settings category that has at least one setting that cannot be shared with all the destination devices, as well as individual settings that cannot be shared.
  • Red text identifies a selected settings category that has at least one setting that has no value defined, as well as individual settings that have no value defined.
    Note
    If no setting is selected, or a setting that cannot be shared with all the destination devices, or that currently has no value defined, is selected, you will be unable to initiate the configuration activity (Finish will be disabled).
Element Description
List Use to select the settings that have the configuration source values you want to share with the selected devices.
Edit Click to edit the value for a selected setting.
Note
If you select a setting that has no value currently defined, you must edit that setting to define a value before you can share it with the selected devices.
Back Click to return to the "Select Destination Devices" display.
Finish Click to apply the selected settings at the destination devices, and exit the "APC SNMP Device Configuration" wizard.
Note
The status of the configuration activity will be reported in the Configuration Status view.
