APC SNMP Device Configuration (Device menu) v7.3.x and above
DCE device configuration
  • EcoStruxure IT Help Center
  • DCE configuration
  • DCE device configuration
  • APC SNMP Device Configuration (Device menu) v7.3.x and above
  • Mark as Read
  • Status messages: Device Configuration Status view
  • Retrieving device settings in the APC SNMP Device ...
  • Modify Device Settings display for Modbus
  • Edit Device Scan Settings display for Modbus
  • Device File Transfer Settings display
  • Copy Register Map to Devices display
  • Configure Device Settings display
  • Building Management Settings display for Modbus
  • Adding or updating device definition files (DDFs) ...
  • APC SNMP Device Configuration wizard results
  • APC SNMP Device Configuration (Device menu) v7.3.x...
EcoStruxure IT Support
Request Support
Back to DCE device configuration
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:12 AM
Configure settings at one or more monitored APC SNMP devices.
Note: You cannot use this option to configure settings for non-APC SNMP devices, NetBotz Appliances and their monitored devices, and some older APC SNMP devices.
Configuration Type display options
These options, and the Configuration Status view, are used by the APC SNMP Device Configuration wizard:
User configuration for NMC v6.0.0 and higher: Configure user management options on devices with firmware v6.0.0 and higher, excluding v6.0.6 - v6.1.1.
All other APC SNMP devices: Select one or more monitored APC SNMP devices and configure them to use settings shared with a selected APC SNMP device, or settings saved as a template.
The "Configuration Type" display is available only when at least one monitored APC SNMP device has firmware v6.0.0 and higher, excluding v6.0.6 - v6.1.1. Otherwise, the "Select a Configuration Action" display is immediately available to configure all other device configuration settings.
Note: You must upload a .csf file directly to the device to configure users on devices with firmware v6.0.6 - v6.1.1. See FAQs on www.apc.com for more information.
User configuration for NMC v6.0.0 and higher option
Select Destination Devices display
Select the destination devices you want to configure user management on.  All the APC SNMP SNMPv1 and SNMPv3 devices monitored by the Data Center Expert server with firmware v6.0.0 and higher, excluding v6.0.6 - v6.1.1, are listed.
Click "Device File Transfer Settings" to manage the File Transfer Protocol (FTP) or Secure Copy (SCP) access values for the APC devices.
User Configuration display
Use this display to select the user management actions you want to configure on all the devices you selected. For specific information about how to configure user actions, see the user guide for your device.
Create/Modify User: Configure the settings for the user you want to create or modify. You must configure this action individually for each user.
Once you specify the username and password, check the box to configure each option.
When you modify a user that already exists on any destination device, all the settings you select, including the password, will be overwritten.
Element Description
Username The name of the user
Password/Confirm Password
Specify the password for a new user or enter a new password for an existing user if you want to change it.
The password is case-sensitive, with a 64 byte maximum (64 ASCII characters, fewer for multibyte languages).
Role
Specify the user role: Administrator, Device, Network only, or Read only
Description
Additional notes to describe the user.
Date Format The date format to display in the device user interface.
Language
The language to display in the device user interface.
Note: This setting will not take affect if the language you choose is not installed on the device.
Units
The units, Metric (the default) or US Customary, to display in the device user interface.
Session Timeout (min)
The amount of time (in minutes) before the user is logged out due to inactivity.
Serial Remote Authentication Override
Specify whether the user can login serially and override a logged in user, even when the device authentication method is set to RADIUS.
Event Log Color Coding
Specify whether text in the event log is color-coded based on event severity.
Log Export Format
The format of the event log when exported: Tab (the default) or CSV.
Enable User
Specify whether the user has access to login in to the device.
Advanced Options
Enter command line parameters to configure additional user options. For example, to configure the role Outlet, enter -pe "Outlet" in this field. For more information, see the Command Line Interface manual for your device at www.apc.com.
Modify Super User:  The name of the super user cannot be changed. The current password for the super user is required.
You can enter a new password for the super user if you want to change it. Otherwise, leave the field blank.
Modify Default User: Additional configuration options to modify the default settings used when a Super User or Administrator for the device creates a new user:
Element Description
Login Attempts
The number of incorrect login attempts a user is allowed before the system disables the account.
Require Strong Passwords
Specify whether new passwords created for users require additional rules, such as: at least one lowercase character, one uppercase character, one number, and one symbol.
Require Password Change (days)
Select the duration (in days) after which the user is required to change the password, 0-365. A value of 0 days (the default) disables this option.
Standard device configuration settings option
Configure devices using a monitored APC SNMP device's settings, create or edit a template, and configure devices using a saved template.
You use the "APC SNMP Device Configuration" wizard to:
Select the APC SNMP device or configuration template you want to use as the source of your configuration activity.
Select destination devices.
See also
Mass Configuration of APC Network Management Card type devices
Changing the protocol used to monitor APC SNMP devices
