APC SNMP Device Configuration wizard results
DCE device configuration
  • EcoStruxure IT Help Center
  • DCE configuration
  • DCE device configuration
  • APC SNMP Device Configuration wizard results
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to DCE device configuration
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:12 AM
The actual value reported by the device after the configuration process may not be shared by the source and destination (Not Supported reported for the Expected Value), the two devices may allow different values, or the set may have failed for an unknown reason.
You can use Launch to Device, a right-click option in the Device View and Map View, to access the device to review its event log to see if it contains information about the error, or to review the user interface at the device to see the available settings, allowed values.
For information about the Status reported for the selected device, see Status messages: Configuration Status view.
