Building Management Settings
DCE device configuration
  • EcoStruxure IT Help Center
  • DCE configuration
  • DCE device configuration
  • Building Management Settings
  • Mark as Read
  • Status messages: Device Configuration Status view
  • Retrieving device settings in the APC SNMP Device ...
  • Modify Device Settings display for Modbus
  • Edit Device Scan Settings display for Modbus
  • Device File Transfer Settings display
  • Copy Register Map to Devices display
  • Configure Device Settings display
  • Building Management Settings display for Modbus
  • Adding or updating device definition files (DDFs) ...
  • APC SNMP Device Configuration wizard results
  • APC SNMP Device Configuration (Device menu) v7.3.x...
EcoStruxure IT Support
Request Support
Back to DCE device configuration
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:12 AM
Last Updated: Sisko JLehr Sisko ‎2024-01-31 01:43 PM
Provides access to a separately-licensed feature you can use to configure the server's MODBUS TCP Output Module support for your Building Management System (BMS).
You cannot configure Building Management System support until you purchase and add the MODBUS TCP Output Module license to Data Center Expert in the System > Server Administration Settings > License Keys option.
Port 502 is used to connect a BMS to the MODBUS TCP Output Module support in DCE.
Three displays are used to configure MODBUS TCP Output Module support:
  • Building Management Settings: Select the devices on which to enable Modbus support and assign the server addresses.
  • Modify Device Settings: Configure the server address for the selected device and map sensors to registers.
  • Copy Register Map: Select the devices to which you want to copy a register map.
See the DCE Building Management System Integration application note
