Copy Register Map to Devices display
DCE device configuration
  • EcoStruxure IT Help Center
  • DCE configuration
  • DCE device configuration
  • Copy Register Map to Devices display
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to DCE device configuration
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:12 AM
Copy the register map settings from the source selected in the "Modify Device Settings" display to one or more of the devices monitored by the server.
Note
Only register map settings that match settings at a selected device will be copied to that device.
Element Description
Search Filter the table to list only entries that include the text you type, exactly as typed.
List Select the device or devices to which you want to copy register map settings from the source selected in the "Modify Device Settings" display.
You can click on any column head (Server Address, Hostname, Device Type, Model, or Location) to sort the list.
Note
All monitored devices are listed, unless filtered.
Select/Deselect All Select (check-mark) or deselect all devices.
