Power dependency description
Configuring power connections
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA desktop client
  • Configuring the ITA desktop client
  • Configuring power connections
  • Power dependency description
  • Mark as Read
  • Working with rack ATS
  • Working with breaker panels
  • Working with Rack PDUs
  • Voltage supported in IT Advisor
  • Reorganizing breaker panels after upgrade
  • Power redundancy
  • Configuring multiple power connections
  • Configuring distributed redundant UPS systems
  • Configuring DC power
  • Power redundancy
EcoStruxure IT Support
Request Support
Back to Configuring power connections
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-06 07:13 AM
The Power Dependency table shows details about power equipment in your data center infrastructure. You can right-click an item (row) to identify it in the layout or navigation, or to open its Properties.
For a better and more graphical overview of your power dependencies, it is recommended to use the Power Path Layout.
Column Description
Item Power equipment items and where they fit in the power path (indention and expandable arrows).
Location Location of the power equipment items in the modeled data center infrastructure.
Phase Phase to which the selected equipment is connected.
Outlet Outlet to which the selected equipment is connected, shown only if rack PDU has power outlets definition.
Breaker module number
Breaker module number (can also be found in Properties > Power > Breaker Panel).
UPS used capacity Power used by equipment connected to this UPS for power.
UPS reserved capacity Power reserved by equipment connected to this UPS for power.
Distribution reserved capacity of UPS size
Relevant for distribution units, such as PDUs, RDPs, and Power Panels. UPS power reserved by this distribution unit (in %).
Distribution reserved UPS capacity
Relevant for distribution units, such as PDUs, RDPs, and Power Panels. UPS power reserved by this distribution unit.
Distribution estimated load
Relevant for distribution units, such as PDUs, RDPs, and Power Panels. Estimated load of equipment connected to this distribution unit for power. In redundancy configurations, this value will include potential failover load.
Distribution unreserved capacity
Relevant for distribution units, such as PDUs, RDPs, and Power Panels. Remaining power available on this distribution unit (total power available minus the load of connected equipment).
Rack remaining power
Relevant if you group racks with similar power requirements (capacity groups). Remaining power available in each rack connected to this distribution unit for power.
Rack maximum capacity
Relevant if you group racks with similar power requirements (capacity groups). The maximum load you can add to each rack connected to this distribution unit for power.
