Configuring multiple power connections
Configuring power connections
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA desktop client
  • Configuring the ITA desktop client
  • Configuring power connections
  • Configuring multiple power connections
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to Configuring power connections
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-06 07:12 AM
You can configure multiple power connections to one rack PDU. The number of connections is limited by the number of power inlets on the rack-mounted equipment.
  1. Right-click the rack-mounted equipment, e.g. server, and select Properties>Power.
  2. Type the number of power inlets.
  3. In Power Cable Connection, select a rack PDU and connect to the relevant outlet if available* or choose phase from available phases.
    Make sure that the number of connections to each rack PDU is in compliance with your redundancy.
*Only for rack PDUs with outlets definition.
