Reorganizing breaker panels after upgrade
Configuring power connections
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA desktop client
  • Configuring the ITA desktop client
  • Configuring power connections
  • Reorganizing breaker panels after upgrade
  • Mark as Read
  • Working with rack ATS
  • Working with breaker panels
  • Working with Rack PDUs
  • Voltage supported in IT Advisor
  • Power redundancy
  • Power dependency description
  • Configuring multiple power connections
  • Configuring distributed redundant UPS systems
  • Configuring DC power
  • Power redundancy
EcoStruxure IT Support
Request Support
Back to Configuring power connections
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-06 07:13 AM
If you have upgraded your installation, you may need to reorganize the breaker panels. This applies specifically to generic PDUs whereas modular PDUs, if correctly configured prior to the upgrade, require minimum configuration.
Generic PDU
When you upgrade from a version prior to 7.4, the breakers will be placed randomly in a placeholder panel. The placeholder panel is a temporary panel and it does not resemble the actual positions of the breakers. To get the benefits of the visual breaker panel, it is important that you reorganize each breaker into the correct position in a new Breaker Panel. This can be done by right-clicking the PDU and selecting Reorganizing Breaker Panel.
Reorganizing Breaker Panels
  1. Right-click a PDU and select Reorganizing Breaker Panels.
  2. If you have already created a panel, you can find it in the drop-down menu in Destination Panel or create and name a new panel.
  3. Move breakers to the destination panel.
    1. To place a breaker in the selected panel, click the desired cell in the panel and select a breaker. Only breakers with matching phases will appear in the drop-down menu. You can toggle this display limitation by using the Strict phase matching check box in the top left corner.
Modular PDU
If the PDU is correctly configured prior to the upgrade, the breaker modules should automatically be placed in the right positions, but it is important that you verify.
For more information on configuring modular and generic PDUs, see here.
