EcoStruxure IT Gateway 1.10.x release notes
Release notes for older Gateway versions
Information about EcoStruxure IT Gateway software releases
  • EcoStruxure IT Help Center
  • Gateway
  • What's new in EcoStruxure IT Gateway
  • Release notes for older Gateway versions
  • EcoStruxure IT Gateway 1.10.x release notes
  • Mark as Read
  • EcoStruxure IT Gateway 1.20.x release notes
  • EcoStruxure IT Gateway 1.19 release notes
  • EcoStruxure IT Gateway 1.18 release notes
  • EcoStruxure IT Gateway 1.17 release notes
  • EcoStruxure IT Gateway 1.16 release notes
  • EcoStruxure IT Gateway 1.15 release notes
  • EcoStruxure IT Gateway 1.14 release notes
  • EcoStruxure IT Gateway 1.13 release notes
  • EcoStruxure IT Gateway 1.12 release notes
  • EcoStruxure IT Gateway 1.11 release notes
  • EcoStruxure IT Gateway 1.9 release notes
  • EcoStruxure IT Gateway 1.8.3 release notes
  • EcoStruxure IT Gateway 1.8.2 release notes
  • EcoStruxure IT Gateway 1.8.1 release notes
  • EcoStruxure IT Gateway 1.7.0 release notes
  • EcoStruxure IT Gateway 1.6.x release notes
EcoStruxure IT Support
Request Support
Back to Release notes for older Gateway versions
  • Mark as Read
Picard EcoStruxureIT
‎2021-03-25 06:29 AM
Gateway 1.10.1
This release addresses an issue in Gateway version 1.10 that prevented some users from logging in to the user interface. All Gateway users can now log in as expected.
Gateway 1.10
New management interface for the Gateway appliance
A more secure and easier-to-use management interface replaced Webmin on the private network of the Gateway appliance. It includes options to manage and configure the appliance private network, public network, and NTP server; controls to reboot, reset, or shut down the appliance; and a command line interface for access to advanced options via SSH.
See EcoStruxure IT Gateway appliance installation and setup - version 1.10 and newer
Gateway appliance OS update in IT Expert
You now update the operating system on Gateway appliances in EcoStruxure IT on the Administration > Gateways tab.
See Updating the Gateway appliance - version 1.10 and newer
Configure SNMP trap ports
The Gateway now listens for traps on port 162 by default for better third party device support.
Note: The Gateway listens for SNMPv1 traps only.
The new Settings > Advanced > SNMP trap ports option allows you to configure SNMP trap ports in addition to 1062. The configurable port list contains port 162 to support the default for most third party devices.
To receive traps for third party devices, you must manually add the Gateway as an SNMP trap receiver in the device's user interface. See Configure SNMP trap ports
GW110_advanced_SNMP_ports_sm_360018815238.pngGW110_advanced_SNMP_ports_sm_360018815238.png
NMC 3 firmware update support
As of this release, you can now use IT Expert to update the firmware on devices that use an APC Network Management Card 3 (AP9640).
Additional device configuration options in IT Expert
More config.ini options are available to update device settings using IT Expert device configuration and single device configuration: device name, location, and contacts.
Domain change to us.ecostruxureit.com
Some URLs used for Gateway communication with EcoStruxure IT reflect outdated branding and are being retired. The URL us.struxureon.com will soon be replaced by us.ecostruxureit.com.
You must define a DNS server for the network that connects to EcoStruxure IT.
Make sure your Gateway can resolve us.struxureon.com and us.ecostruxureit.com via DNS.
Note: Firewall settings to connect using static IP addresses 40.84.62.190, 23.99.90.28 and 52.230.227.202 are unaffected by this change.
See System requirements for EcoStruxure IT Gateway
Security
See EcoStruxure IT security
