EcoStruxure IT Gateway 1.7.0 release notes
Release notes for older Gateway versions
Information about EcoStruxure IT Gateway software releases
  • EcoStruxure IT Help Center
  • Gateway
  • What's new in EcoStruxure IT Gateway
  • Release notes for older Gateway versions
  • EcoStruxure IT Gateway 1.7.0 release notes
  • Mark as Read
  • EcoStruxure IT Gateway 1.20.x release notes
  • EcoStruxure IT Gateway 1.19 release notes
  • EcoStruxure IT Gateway 1.18 release notes
  • EcoStruxure IT Gateway 1.17 release notes
  • EcoStruxure IT Gateway 1.16 release notes
  • EcoStruxure IT Gateway 1.15 release notes
  • EcoStruxure IT Gateway 1.14 release notes
  • EcoStruxure IT Gateway 1.13 release notes
  • EcoStruxure IT Gateway 1.12 release notes
  • EcoStruxure IT Gateway 1.11 release notes
  • EcoStruxure IT Gateway 1.10.x release notes
  • EcoStruxure IT Gateway 1.9 release notes
  • EcoStruxure IT Gateway 1.8.3 release notes
  • EcoStruxure IT Gateway 1.8.2 release notes
  • EcoStruxure IT Gateway 1.8.1 release notes
  • EcoStruxure IT Gateway 1.6.x release notes
EcoStruxure IT Support
Request Support
Back to Release notes for older Gateway versions
  • Mark as Read
Picard EcoStruxureIT
‎2019-09-05 05:20 AM
It is recommended that you upgrade to 1.7.0.64 to mitigate potential security vulnerabilities.
Is your Gateway software older than 1.4.0? Download and install version 1.5.2 before you update to the latest version.
If your Gateway software is older than version 1.4.0, the installer will direct you to download and install Gateway version 1.5.2. Once you log in, you'll see a message that an update is available. You can then update your Gateway to the latest version.
If your Gateway version is 1.4.0 or newer, you can update to the latest version directly.
Log in to your EcoStruxure IT account. Go to Administration > Gateways. Click Update on the gateway tile.
You can enable automatic Gateway software updates in EcoStruxure IT. More
EcoStruxure IT Gateway 1.7.0.64
California state legislature security updates for network-connected devices
EcoStruxure IT Expert Gateway was updated to comply with California law for the security of connected devices.
APC network-enabled devices are being updated to improve security and comply with regulations.
New versions of APC Network Management Card (NMC) firmware will have the SNMP protocol disabled by default. Devices that have these cards cannot be discovered by EcoStruxure IT Expert or Data Center Expert until SNMP is enabled.
More information on specific changes
This release provides support for NetBotz 750.
Device support
  • NetBotz 750 support, requires a minimum of NetBotz 750 version 5.2.0
  • Enhanced support for APC UPS
System updates
  • The APC Network Management Card is no longer listed as a device in the EcoStruxure IT Inventory.
  • You can now launch to a device from the Gateway using either HTTPS or HTTP.
  • Units for Apparent Energy (VAh) and Reactive Energy (VARh) are now displayed as expected.
Security
Various security improvements
Checksum
SHA1
Linux:  3f6e828a9928007d4ef0a868c9452e3194393991
Windows:  b7ae6cec249e2c34907ab4a112cff2a6a8fd0012
