EcoStruxure IT Gateway 1.9 release notes
Release notes for older Gateway versions
Information about EcoStruxure IT Gateway software releases
Send InviteCancel
The EcoStruxure IT Gateway password policy now requires:
At least 10 characters in length
At least 3 of the following 4 types of characters:
Lower case letters (a-z)
Upper case letters (A-Z)
Numbers (0-9)
Special characters (Example: !@#$%^&*)
No more than 2 identical characters in a row (Example: aaa is not allowed)
Strong passwords are enforced when you first create your password and when you change your password. You are not required to change your existing password after updating your Gateway.
SCP support
SCP is now supported as a secure alternative to FTP for event.txt, device configuration, and firmware update. It is strongly recommended that you use SCP and disable FTP on your APC NMC-based devices.
IMPORTANT: You must update the device configuration settings in the Gateway and rediscover the devices that you modified to use SCP credentials. See Configure Gateway device file transfer settings
Log rotation
Gateway log rotation on Linux installations now occurs as expected.
Backup output email
An email is no longer sent for a Gateway backup on Linux installations, was previously sending large email for each backup. Backup results are still stored in cli.log.
