EcoStruxure IT Gateway 1.8.2 release notes
Release notes for older Gateway versions
Information about EcoStruxure IT Gateway software releases
  • EcoStruxure IT Help Center
  • Gateway
  • What's new in EcoStruxure IT Gateway
  • Release notes for older Gateway versions
  • EcoStruxure IT Gateway 1.8.2 release notes
  • Mark as Read
  • EcoStruxure IT Gateway 1.20.x release notes
  • EcoStruxure IT Gateway 1.19 release notes
  • EcoStruxure IT Gateway 1.18 release notes
  • EcoStruxure IT Gateway 1.17 release notes
  • EcoStruxure IT Gateway 1.16 release notes
  • EcoStruxure IT Gateway 1.15 release notes
  • EcoStruxure IT Gateway 1.14 release notes
  • EcoStruxure IT Gateway 1.13 release notes
  • EcoStruxure IT Gateway 1.12 release notes
  • EcoStruxure IT Gateway 1.11 release notes
  • EcoStruxure IT Gateway 1.10.x release notes
  • EcoStruxure IT Gateway 1.9 release notes
  • EcoStruxure IT Gateway 1.8.3 release notes
  • EcoStruxure IT Gateway 1.8.1 release notes
  • EcoStruxure IT Gateway 1.7.0 release notes
  • EcoStruxure IT Gateway 1.6.x release notes
EcoStruxure IT Support
Request Support
Back to Release notes for older Gateway versions
  • Mark as Read
Picard EcoStruxureIT
‎2020-05-11 05:56 AM
Updating the Gateway from 1.8.1 to the current version
There is an issue updating Gateway 1.8.1 to the current Gateway version.
Only the update from version 1.8.1 is affected. Updating from Gateway 1.7.0 and earlier is not affected. Updating from 1.8.2 and later is not affected.
Windows
Due to an issue with 1.8.1, the software update from 1.8.1 to 1.8.2 appears to fail when performing an upgrade from the EcoStruxure IT Web application. This failure message is erroneous.
It can take up to 30 minutes for the Gateway to start running the new version and to clear the message. If the message doesn't clear, contact support for assistance.
Linux
Due the same issue in 1.8.1, the update from the EcoStruxure IT Web application will always fail.  If you have installed Gateway version 1.8.1 on a computer, updating to 1.8.2 requires that you manually download and install the installation file from EcoStruxure IT.
To update the software on a Gateway appliance, contact support for assistance.
DDF updates
Corrected the name of the controller in some Uniflair Modbus DDFs
Improvements for Uniflair Modbus device discovery
Other improvements
Improved the Gateway software update process
See also
Updating EcoStruxure IT Gateway to the latest version
