EcoStruxure IT Gateway 1.20.x release notes
Release notes for older Gateway versions
Information about EcoStruxure IT Gateway software releases
  • EcoStruxure IT Help Center
  • Gateway
  • What's new in EcoStruxure IT Gateway
  • Release notes for older Gateway versions
  • EcoStruxure IT Gateway 1.20.x release notes
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to Release notes for older Gateway versions
  • Mark as Read
Sisko JLehr Sisko
‎2023-09-14 12:27 PM
It is strongly recommended that you update your Gateway to the latest version. See how
Gateway 1.20.2
Enhancements
  • This release replaces a certificate that enables device library updates.
    The Gateway must be at a minimum of version 1.20.2 to receive new device library updates.
    See How to update the Gateway device library
Gateway 1.20.1
Issues fixed
  • Incomplete firmware updates are now terminated as expected when the Gateway is rebooted.
Gateway 1.20.0
Enhancements
  • Firmware update and device configuration improvements
  • You can now select specific device file transfer credentials to use in a device discovery.
    Click Configure Credentials to select only the credentials to use for the devices being discovered. Otherwise, all configured credentials will be used.
    idea_icon.png  Click Manage credentials to view the credentials you have configured in the Gateway.
    To comply with stricter cybersecurity requirements across various product groups, it is recommended that you review your username/password lists in EcoStruxure IT Gateway and confirm that configured credentials are both active and accurate.
    See New cybersecurity requirements in NMC3
Issues fixed
  • Polling is disabled during device firmware update to prevent erroneous alarms.
  • Sorting the IP address column on the Devices page or editing the polling interval no longer displays a 400 error.
  • The device discovery summary no longer shows deleted credentials as invalid.
Known issues
Complete list of EcoStruxure IT Gateway known issues
