Posted: 2020-07-05 05:50 PM . Last Modified: 2024-04-03 03:13 AM
NetBotz monitoring SNMPv3
(CID:140712449)
NetBotz
Posted: 2020-07-05 05:51 PM . Last Modified: 2024-04-03 03:13 AM
Dear Luciano,
Hopefully, according to Release Notes NetBotz v4.6.4.pdf, you reboot your appliance, as outlined in section Known Issues:
I hope this is what you need.
With respect.
(CID:140712469)
Dear Luciano,
With respect.
(CID:140712469)
Hi my friend,
I will validate and report here in this post.
Thank you for your help.
Att/Regards,
Luciano da Silva Gomes.
(CID:140712513)
I performed the tests as directed, and it worked correctly.
I just updated the SNMP settings, created a new user to make sure the settings and everything went well after a manual Reboot (NetBotz Advanced View > Tools Reboot Appliance).
Thank you very much for your help.
Att/Regards,
SysAdmin At BRASCLOUD.
(CID:140712834)
Ok, very thanks for the good feedback 😀.
(CID:140712862)
Posted: 2020-07-05 05:51 PM . Last Modified: 2024-04-03 03:12 AM
Hi Luciano,
The first thing I notioced is that you're set up for MD5 AND DES yet your command-line is set to "authNoPriv. If both are configured, it should be "authPriv". Here's how I set up for authNoPriv:
C:\usr\bin>snmpget -v3 -u Luciano -a MD5 -A LucianoLuciano -l authNoPriv 570-1 .
1.3.6.1.2.1.1.3.0
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (746) 0:00:07.46
(CID:140712669)
Just an FYI, my free command-line SNMP utility does not support encryption so I could not use DES. DCE 7.6 has an SNMPwalk utility on it's web page which I was able to use for MD5 and DES on a walk to that same bot running 4.6.3::
(CID:140712697)
When I try to run SNMPWALK with the incorrect Security Level settings, the following error is returned:
snmpwalk: USM generic error
So I believe that the problem really was related to the problem described by Spezialist.
I greatly appreciate your help, it is a very healthy and participative community.
Att/Regards,
Luciano da Silva Gomes,
(CID:140712768)
Posted: 2020-07-05 05:51 PM . Last Modified: 2023-10-22 03:15 AM
