DCE SNMPv3
  • DCE SNMPv3
129
72
Nirmolak
Nirmolak
Cadet
Posted: ‎2024-05-31 08:19 PM
1230
DCE SNMPv3
I have Raritan IPDUs registered in DCE via SNMP v1.
I wish to upgrade them to SNMP v3, and re-register them via SNMP v3 into DCE.
Based on testing, the only way is to remove the device, then re discover them via SNMP v3.
But this causes me to lose all historical data as well virtual sensors.
Is there any way to change from SNMP v1 to v3 for Raritan devices without losing history?
Admiral
Posted: ‎2024-06-03 08:54 AM
Hi @Nirmolak,
Currently there is no way to switch 3rd party devices from SNMPv1 to SNMPv3 without deleting and rediscovering the device.
Our engineering team is currently working on an easy way to switch devices between SNMPv1 and SNMPv3 and it is currently expected to launch in the next version of Data Center Expert.  To stay up to date on release notifications you can log into the EcoStruxure IT Entitlements site and follow the directions here: https://ecostruxure-it-entitlements.se.com/csm?id=kb_article_view_cs&sysparm_article=KB0018943
If you do not have access to EcoStruxure IT Entitlements for your account, please reach out to technical support.
Kind Regards,
Cory
Gabi
Lieutenant Gabi
Lieutenant
Posted: ‎2024-06-03 04:08 AM
from what I know you cannot switch to snmp v3 without removing and rediscover....since every device receive an id number(in DCE database and config) even if you remove and rediscover any device without any config change(ip,hostname,snmp), the new discovered device receive a new id without any pointers to the old id
Admiral
Hi @Nirmolak,
Kind Regards,
Cory
JLehr
Sisko JLehr Sisko
Sisko
Posted: ‎2024-06-04 12:51 PM . Last Modified: ‎2024-06-04 12:51 PM
There are several ways to be notified about software releases. You can opt in to notifications in the Entitlements portal, and you can subscribe to what interests you in the forum and help center.
See how
