Posted: 2020-07-05 05:51 PM . Last Modified: 2024-04-03 03:12 AM
Hi Team,
Asking on behalf of the customer Jimmy Leung.
In the current version of DCO a CRAC unit monitored by DCE will show the Temprerature and Humidity sensors that can subsequently be positioned on the floor in the DCO layout.
Are there any plans in bringing across other sensors like fan speed and cooling output figures so DCO can use those and adjust the cooling calculations?
(CID:140712543)
Posted: 2020-07-05 05:52 PM . Last Modified: 2024-04-03 03:12 AM
Hi Lukasz,
For the time being there are no plans to change the DCE sensor mapping functionality to DCO (https://sxwhelpcenter.ecostruxureit.com/display/DCIMDEVELOPER/DCE+Sensor+Mapping+to+DCO). However, the near future plan is to add more functionality into the webclient.
Kind regards
(CID:140712639)
Hi Lukasz,
Kind regards
(CID:140712639)
Thanks Jeff,
Could you kindly log it as a Feature Request.
I will send end user details over direct email.
(CID:140712922)
Posted: 2020-07-05 05:52 PM . Last Modified: 2023-10-22 01:46 AM
