NetBotz - UPS Monitoring
  • EcoStruxure IT forum
  • NetBotz - UPS Monitoring
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 10:39 PM . Last Modified: ‎2024-04-09 01:23 AM
1384
Dear Team,
I have installed the NetBotz Device Monitoring node license for NetBotz and managed add SUVT and G300 UPS using the Scanned Device Configuration Utility.
Question: As shown below I can only see a single parameter monitoring on this UPS, do I need to get the DDF for the UPS to see more parameters to be monitored? or this is the best it can get?
The reason for this monitoring is to have SMS alerts for the UPSs in case of any alarms.
Felix.
(CID:105461107)
  • NetBotz
1384
Hi Felix,
On the bottom left panel in Advanced View, you should have a drop-down list next to Sets.
This defaults to Device Status, but if you click on this, you should see more sensor options in the drop-down list, like All sensors, UPS Battery Status, etc.
Regards
(CID:105461241)
Replies 6
1385
Hi Felix,
Regards
(CID:105461241)
Hi John, I wish to filter my alerts to the below which are more important to the customer. UPS on Battery power. Phase Rotation Detected. UPS on Static Bypass due to UPS fault. How well can I achieve this from the existing UPS alert option. Regards, Felix
(CID:105465034)
Hi Felix, For the UPS on battery and UPS in Bypass events, you should select Device Status next to Sets. Then right click on the Device Status sensor for the relevant UPS, and select Configure sensor. Then Add the Alert State Threshold and make sure it is Enabled. For the Phase Rotation event, you should select UPS Main Input Status next to Sets. Then select the Main Input Phase Orientation sensor and then follow the same instructions for adding the Alert State Threshold for that sensor. I hope this helps, but let me know if you need anything clarified. Regards
(CID:105465226)
Hi John, Thank you. I was hoping to have just the on battery power and on static bypass alert but then I get other alerts once I configure the UPS. should I filter this from the UPS? the customer doesn't want to receive too many SMS alerts. Regards, Felix
(CID:105465435)
Hi Felix, With NetBotz, I don't think it is possible to configure notifications for specific alerts like you can do with DCE. Regards
(CID:105465721)
Posted: ‎2020-07-02 10:39 PM . Last Modified: ‎2023-10-31 11:26 PM
