Forgotten or unknown password
  • Forgotten or unknown password
  • RandyDavis
    RandyDavis
  • RobertAndriolo
    RobertAndriolo
  • Reza
    Reza
  • JonGreen
    JonGreen
  • Jonas_Brissman
    Jonas_Brissman
  • PeterEdvik
    PeterEdvik
  • Alan_Wood
    Alan_Wood
  • StephenYang
    StephenYang
  • Gary
    Gary
  • Jonathan
    Jonathan
  • DavidChild
    DavidChild
‎2020-09-25 09:38 AM
Last Updated: Admiral StephenYang Admiral ‎2025-06-10 10:23 AM
Unable to log into Workstation because the user password is unknown.
  • Building Operation Workstation
  • Building Operation Automation Server (AS, AS-P, or AS-B)
  • Building Operation Enterprise Central
  • Building Operation Project Configuration Tool (PCT)
The password for an Automation server or Enterprise server/Central has been forgotten.
IMPORTANT:
The session ID is unique for this session of WorkStation. You cannot close WorkStation until the password has been reset. If you close WorkStation, before the password has been reset, a new session ID is generated that cannot be used with the temporary password provided by your local Schneider Electric Buildings support team.
The following are the steps to populate the session ID, which is required for doing the password reset.
For servers with EBO older than V3.1.X
  1. In the WorkStation logon page, while holding the shift key, left-click the area near the EcoStruxure Building Operations Icon.
  2. This will populate the Session ID. Copy the Session ID.
For servers with EBO V3.1.X:
  1. In Device Administrator, select the server you need to perform the reset to. Check the box and click the hyperlink
  2. From the top bar select Password Reset
  3. Select OK when you get the “Password reset token created” pop-up2020-07-21_11-24-23.png
  4. Now, on the WorkStation logon page, while holding the shift key, left-click the area near the EcoStruxure Building Operations Icon.
  5. This will populate the Session ID. Click the Copy button.
For servers with EBO V3.2.X and higher
  2. From the top bar, select the “Edit Connection Password/Reset password” and press OK
  3. Now, on the WorkStation logon page, while holding the shift key, left-click the area near the EcoStruxure Building Operations Icon.
  4. This will populate the Session ID. Click the Copy button.
For servers within PCT 2.X
  1. Start the server
  3. Select "Set password reset mode"
NOTE (for servers with EBO V3.1.X and higher)
  • For the Automation Server password reset, ensure that the Automation Server is connected to your PC machine via a USB cable.
  • For the Enterprise server and Enterprise Central password reset, add the server to the Device Administrator using the “Add Server” button on the top bar. Please note even if you enter the wrong password, the Server would still be added to the Device Administrator.
After having the Session ID:
  1. Send the Session ID to your local Schneider Electric Buildings support team
  2. Once PSS provides you with the unlock key
  3. In WorkStation, ensure that the Session ID is still visible, enter:
    User Name: admin
    Password: paste the result from the webpage
    Domain: Local
    and click Log On
  4. This will pop-up the Change-Password form
    1. Fill in the “old password” field with the unlock Key
    2. Put in a new password you want to use and then enter the new password in again.
NOTE:
When attempting to reset the password and unlock with the sessionid/temp password, you receive the error:
"Your account has insufficient permission to use the system. Contact your administrator. "
 Open a case with your local Product Support group and submit a request to unlock the user.
NOTE:
WebHelp article 6749
The following video shows the password reset procedure for EBO older than V3.1.X. It covers most of the important steps for newer versions.
Quick-Help video
Tags (32)
  • 10905
  • 24
  • 24-hour
  • admin
  • administrator
  • as-p
  • asp
  • ebo
  • GaryMontague20
  • hour
  • JonasBrissman21
  • JonGreen20
  • lockout
  • lost
  • name
  • need
  • over
  • override
  • PeterEdvik20
  • pwd
  • recovery
  • relinquish
  • request
  • reset
  • RezaAmirzadeh22
  • ride
  • session
  • StephenYang25
  • temp
  • temporary
  • under
  • username
77% helpful (10/13)
