Network cable management in the IT Advisor web client
Working with the inventory
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA web client
  • Working with the inventory
  • Network cable management in the IT Advisor web client
  • Mark as Read
  • Asset management features in the IT Advisor web cl...
  • Floor overlays
  • Editing rack inventory
  • Power connections wizard in floor view
  • Power connections wizard in rack view
  • Link mode
  • Searching the inventory
  • IT Design CFD integration in IT Advisor
  • Cooling overlay in the IT Advisor web client
  • Cable tray management in the IT Advisor web client
  • Create bus bars in the IT Advisor web client
  • Connect a device to a bus bar tap off box in the I...
  • Create infrastructure tiers in the ITA web client
  • Breaker panel management in the IT Advisor web cli...
  • Network cable management in the IT Advisor web cli...
  • Floor overlays
  • Link mode
EcoStruxure IT Support
Request Support
Back to Working with the inventory
  • Mark as Read
Sisko JLehr Sisko
‎2025-12-08 08:45 AM
on ‎2025-12-08 08:45 AM
In the Network context of the floor view, use the network connection wizard to create, edit, and delete network connections between assets in racks, in rooms, and between patch panels.
To launch the network connection wizard:
  1. Select a location and then select the Network context.
  2. Click Network to display the information pane.
  3. Select an asset with network ports.
  4. Select Network Connect to launch the network connection wizard.
Create an in-rack connection
In the network cnnection wizard:
  1. Select the location of the destination asset.
  2. Click Next if you select Current Rack. Otherwise select the destination rack or asset and then click Next.
  3. Specify the cable type information.
  4. Select the destination asset.
  5. Select the source and destination ports and click Confirm to save the network connection.
  6. Click Create more or Finish to exit the wizard.
