Ask Me About Webinar: Data Center Assets - Modeling, Cooling, and CFD Simulation Join our 30-minute expert session on July 10, 2025 (9:00 AM & 5:00 PM CET), to explore Digital Twins, cooling simulations, and IT infrastructure modeling. Learn how to boost resiliency and plan power capacity effectively.Register now to secure your spot!
Send InviteCancel
The web client rack inventory allows you to see any part of the ITA data center infrastructure model you have access to and drill down through locations and rooms to the rack inventory.
You may have been granted rights to view or edit all or parts of the rack inventory.
Infrastructure overview and drill down
Locations and rooms from the ITA desktop client are represented in the web client in a non-hierarchical structure, making it easy to click or tap through locations, rooms, cages, and racks to a specific server or other asset in a rack.
Room
The room layout provides an overview of the floor-mounted equipment in the room. You can switch between overlays to reveal relevant details on top of your equipment, such as power as graphs and numbers, and available u-space.
This information is also available as property tiles to the right of the layout. The information updates with relevant information for the selected equipment.
The audit trail reflects any changes to the selected room or equipment.
Zoom and overview
Use the zoom and full screen options to get a better view of specific details or an overview of the full solution.
Open rack
Double-click a rack to open it in the rack layout.
Cage
If you are using IT Advisor for Colo, you can see the cages you have been granted access to in the room layout.
Glass
Light blue
Mesh
Dotted lines
Solid
Black
Rack
The rack layout provides an overview of the rack-mounted equipment in the selected racks and enables you to edit your rack inventory.
Expand/collapse rack
Use the expand/collapse icon to toggle viewing a rack from the front only or from the front and rear at the same time, for example to see rear-mounted rack PDUs.
Open multiple racks
Click the + icon to open multiple racks at the same time, allowing you to compare or drag equipment between them.
If you open several racks, selecting zoom fit and full screen view will allow you to better see all racks at the same time.
Show sensors in rack
If you want to see temperature sensor data displayed directly in the rack layout at the sensor's position, select to show sensors.
Editing rack inventory
In the web client, changes to the rack inventory happen immediately. You don't have to click to save your changes as in the desktop client. And there's no undo.
If you regret adding a piece of equipment, delete it; if you regret moving a piece of equipment, move it back.
In case you accidentally make a quick move and didn't pay attention to where the equipment ended up, use the audit trail.
Adding equipment
In the rack layout, open the rack where you want to position the new equipment.
Click ADD EQUIPMENT to open the Equipment library.
Find the equipment to add by searching the library.
Drag it into the rack.
Moving equipment
In the rack layout open both the source and target racks.
Double-click to open the source rack.
Click COMPARE above this rack to open a list of other racks in the room.
Select the target rack from the list of racks.
Drag the piece of equipment you want to move from the source rack into position in the target rack.
Deleting equipment
Select the equipment you want to delete.
Click Actions... in the information panel to the right of the layout, and select Delete.
Auditing rack inventory changes with the audit trail
Use the audit trail to monitor rack inventory changes on-the-fly. Click the icon in the Elevated view to the right of the rack layout.
There is no need to generate a report. It updates immediately as you add, move, or delete equipment, disconnect cables, or make other changes.
