Cable tray management in the IT Advisor web client
Working with the inventory
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA web client
  • Working with the inventory
  • Cable tray management in the IT Advisor web client
  • Mark as Read
  • Asset management features in the IT Advisor web cl...
  • Floor overlays
  • Editing rack inventory
  • Power connections wizard in floor view
  • Power connections wizard in rack view
  • Link mode
  • Searching the inventory
  • IT Design CFD integration in IT Advisor
  • Cooling overlay in the IT Advisor web client
  • Create bus bars in the IT Advisor web client
  • Connect a device to a bus bar tap off box in the I...
  • Create infrastructure tiers in the ITA web client
  • Breaker panel management in the IT Advisor web cli...
  • Network cable management in the IT Advisor web cli...
  • Floor overlays
  • Link mode
EcoStruxure IT Support
Request Support
Back to Working with the inventory
  • Mark as Read
Sisko JLehr Sisko
‎2025-07-07 03:37 PM
on ‎2025-07-07 03:37 PM
You can create cable tray sections and drop tray sections in both the IT Advisor web and the desktop client.
Note: Creating and managing network connections is currently limited to the desktop client.
Create cable tray sections
Select the Room Editor context.
Click the Add Fixture icon on the left.
Click Cable Tray Sections.
Select the Infrastructure Tier.
Select the Cable Tray Type (optional).
Select the Cable Tray Material (optional).
Use the cursor to draw the cable tray section. Overlap sections to connect one section to another.
Note: You can set the cable tray name in the Asset properties view.
Create a cable tray drop tray
Click Drop Tray.
Select the Infrastructure Tier that contains the bus bar.
Specify the drop tray Height (optional).
Use the cursor to place the drop tray on the cable tray.
