Connect a device to a bus bar tap off box in the IT Advisor web client
Working with the inventory
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA web client
  • Working with the inventory
  • Connect a device to a bus bar tap off box in the IT Advisor web client
  • Mark as Read
  • Asset management features in the IT Advisor web cl...
  • Floor overlays
  • Editing rack inventory
  • Power connections wizard in floor view
  • Power connections wizard in rack view
  • Link mode
  • Searching the inventory
  • IT Design CFD integration in IT Advisor
  • Cooling overlay in the IT Advisor web client
  • Cable tray management in the IT Advisor web client
  • Create bus bars in the IT Advisor web client
  • Connect a device to a bus bar tap off box in the I...
  • Create infrastructure tiers in the ITA web client
  • Breaker panel management in the IT Advisor web cli...
  • Network cable management in the IT Advisor web cli...
  • Floor overlays
  • Link mode
EcoStruxure IT Support
Request Support
Back to Working with the inventory
  • Mark as Read
Sisko JLehr Sisko
‎2025-07-07 03:38 PM
on ‎2025-07-07 03:38 PM
Go to the Power context.
Select a rack PDU from the Rack view or the pinned view.
Select the Power pane.
In the Power Connections section, click Connect.
Select Current Room. In this example, the tap off box is in the same room as the rack PDU.
Select the Intrastructure Tier.
Select the tap off box or click the device in the room preview pane.
Set the connection properties:
  • Breaker model
  • Position
  • Phase
  • Name
Click Confirm to create the power connection.
