Create bus bars in the IT Advisor web client
Working with the inventory
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA web client
  • Working with the inventory
  • Create bus bars in the IT Advisor web client
  • Mark as Read
  • Asset management features in the IT Advisor web cl...
  • Floor overlays
  • Editing rack inventory
  • Power connections wizard in floor view
  • Power connections wizard in rack view
  • Link mode
  • Searching the inventory
  • IT Design CFD integration in IT Advisor
  • Cooling overlay in the IT Advisor web client
  • Cable tray management in the IT Advisor web client
  • Connect a device to a bus bar tap off box in the I...
  • Create infrastructure tiers in the ITA web client
  • Breaker panel management in the IT Advisor web cli...
  • Network cable management in the IT Advisor web cli...
  • Floor overlays
  • Link mode
EcoStruxure IT Support
Request Support
Back to Working with the inventory
  • Mark as Read
Sisko JLehr Sisko
‎2025-07-07 03:38 PM
on ‎2025-07-07 03:38 PM
Bus bar management was introduced in the IT Advisor web client in version 9.5.2.
  • Bus bars are defined as room fixtures like rows, and containment systems and must be assigned to an infrastructure tier.
  • Bus bars have genomes.
  • Bus bars can be visualized from the overlays pane.
  • Bus bars appear like PDUs when viewing the power path.
Power connections to bus bar tap down boxes can be managed in both the web client and the desktop client.
Note: Bus bar features in the desktop client are limited:
  • Bus bars cannot be created or managed in the desktop client.
  • Bus bars do not appear in the 3D view or room overlays in the desktop client.
Create a bus bar
Select the Room Editor context.
Click the Add Fixture icon on the left.
Click Bus Bar Section.
Select the Infrastructure Tier.
Select the Genome for the bus bar.
Select the Shape and Material (optional).
Use the cursor to draw the bus bar section. Overlap sections to connect one section to another.
Note: You can set the bus bar name in the Asset properties view.
Create a bus bar tap off box
Click Bus Bar Tap Off Box.
Select the Infrastructure Tier that contains the bus bar.
Specify the Panel Name for the tap off box. The name must be unique.
Specify the Panel Size, the number of breaker poles.
Specify the Start, the first pole number.
Specify the Breaker Panel Rating.
Next, connect the device to the bus bar tap off box
