Breaker panel management in the IT Advisor web client
Working with the inventory
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA web client
  • Working with the inventory
  • Breaker panel management in the IT Advisor web client
  • Mark as Read
  • Asset management features in the IT Advisor web cl...
  • Floor overlays
  • Editing rack inventory
  • Power connections wizard in floor view
  • Power connections wizard in rack view
  • Link mode
  • Searching the inventory
  • IT Design CFD integration in IT Advisor
  • Cooling overlay in the IT Advisor web client
  • Cable tray management in the IT Advisor web client
  • Create bus bars in the IT Advisor web client
  • Connect a device to a bus bar tap off box in the I...
  • Create infrastructure tiers in the ITA web client
  • Breaker panel management in the IT Advisor web cli...
  • Network cable management in the IT Advisor web cli...
  • Floor overlays
  • Link mode
EcoStruxure IT Support
Request Support
Back to Working with the inventory
  • Mark as Read
Sisko JLehr Sisko
‎2025-12-08 08:44 AM
Manage breaker panel settings and connections in the Power context. You can modify the breaker panel name, panel derating, and breaker connection information.
  1. In the floor view, select the Power context.
  2. Select a power device with a breaker panel.
  3. Select Power to display the information for the breaker panel.
  4. Select Manage Panels.
Edit breaker panel settings
To modify breaker panel name, panel derating, and breaker connection information:
  1. Click Manage Panels in the Breaker Panels section in the Power pane.
  2. Click Edit Breaker Panel.
  3. Modify the Panel name and Panel wide breaker derating, and specify or edit the assigned Breaker and assigned Power Consumer.
    Click Save.
