V2 Harmonic reading double what V1 or V3 are reading PM8000
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Re: V2 Harmonic reading double what V1 or V3 are reading PM8000
Charles_Murison
Charles_Murison Champion
571
Mehran_Mehrnia
Mehran_Mehrnia Champion
203
Ramasamy_N
Ramasamy_N Champion
115
Jeremy.Sexton
Jeremy.Sexton Explorer
Explorer
Posted: ‎2022-08-23 12:56 PM
2613
I have a customer with a PM8000 that has an alarm for Over THD V2. V2 is reading a littel over 7.2 and the high setpoint is 5.  V1 and V3 are both reading about 3.6.  All other meters in the area show all three at about 3.2-3.8.  Is there a way to check or calibrate this input on a PM8000? Firmware is 3.1.  Meter SN is ME-2001A089-02.
  • PM8000
Charles_Murison
Champion
Posted: ‎2022-08-23 01:43 PM
1
2610
Hello @Jeremy.Sexton ,
Calibrate, no, there is not field calibration for the PM8000 meters for any measurement. What you can do is take a manual waveform capture, export the data, then do analysis on this data and compare to the meter's readings. It is also possible if you view the waveform you may see some of the distortion on V2.
Examples of the analysis could be Fast Fourier Transform (FFT) to get the different frequency components.
Charles
Replies 4
Charles_Murison
Champion
1
2611
Charles
Bojan
Bojan Leader
Leader
Posted: ‎2022-08-23 02:05 PM
2606
Check the control power wiring - if the meter power supply is taken from V3 PT, instead of a separate step down transformer, it could cause a ripple in the reference voltage.
Jeremy.Sexton
Explorer
Posted: ‎2022-08-26 12:14 PM
Thank you.  We checked this and the meter control power is coming from a separate source.
Jeremy.Sexton
Explorer
Posted: ‎2022-08-26 12:15 PM
Thank you.  We are working with the customer to evaluate the power quality on site.
