ION Device Template Reference Possible update
Metering & Power Quality
Select a Country
  • EcoStruxure Power & Grid
  • ION Device Template Reference Possible update
Charles_Murison
Charles_Murison Champion
566
Mehran_Mehrnia
Mehran_Mehrnia Champion
194
Ramasamy_N
Ramasamy_N Champion
115
Charles_Murison
Champion
Posted: ‎2020-11-02 05:01 PM
30
16397
Hello all,
Looking to possibly revise the ION Device template reference for the newer ION meters (ION9000, PM8000, ION7400) only. This will not replace the older .chm file but rather be an extension in a new format. Given that this is something new we have the chance to make some changes. What I would love to know from you:
A) What information are you looking for in this file? What information inside the current document would you like to see in something new.
B) What format would you like this new file? .chm is old and likely not going to be used moving forward.
C) If possible what kind of navigation would you like to see?  (Does depend on the file type chosen)
Charles
  • ION7000
  • ION9000
  • PM8000
Charles_Murison
Champion
Posted: ‎2020-11-19 08:39 PM
5
16312
Hello All,
Below are some screenshots at my first prototype. Any data seen in these screenshots may not exist in actual device
Summary page
Module counts
Data recorder
@Grant_IPACS
@Arneil_Dalope
@richard_schwass
@kyle_coveart
Replies 30
Tom_Stevenson
Tom_Stevenson Champion
Champion
Posted: ‎2020-11-03 01:37 PM
@JamesAZZO mentioned to me the need was for # of modules utilized and the capacity of each module type and Excel as the format.  Tagging James to keep me honest 🙂
Tom
Grant_IPACS
Grant_IPACS
Mentor
Posted: ‎2020-11-03 03:53 PM
16387
Hi @Charles_Murison ,
got any examples in mind?
personally any TXT file with ALL settings is enough for us, simple, lightweight, opens with generic s/ware.
It would be good to include those advanced setting in the file too.
Regards
Grant
Charles_Murison
Champion
Posted: ‎2020-11-03 04:03 PM
Hello @Grant_IPACS ,
Nothing set in stone yet. As Tom mentioned there has been mostly requests for information regarding the number of modules in a framework and the maximum number of modules in a version of firmware. One of the easiest ways to represent this information is in a table, possibly excel file, possibly csv file, could even be a text file or even html file to list a few. Wanted to get some feedback from others as soon as possible before too many decisions were may that would prevent one option or another.
Charles
kyle_coveart
kyle_coveart Troubleshooter
Troubleshooter
Posted: ‎2020-11-05 07:57 AM
I'm not sure about the feasibility of this request, but it would be nice to see a graphical representation of the framework. Yes, I know we have Designer, but that doesn't always give a clear picture as to how the framework is constructed.
In order to see how data flows through this framework, and what modules are linked to what, it requires lots of clicking back and forth on various modules.
The current Device Template Reference does a good job of showing each individual modules inputs / outputs and setup registers and where they are linked, but it's not graphical.
Something like this (taken from ION Reference) would make it very easy to see how frameworks are constructed.
Again, probably not feasible, but would certainly be useful.
Tom_Stevenson
Champion
Posted: ‎2020-11-06 06:49 AM
@Arneil_Dalope
richard_schwass
richard_schwass
Explorer
Posted: ‎2020-11-08 01:04 PM
16363
Hi Charles,
We use this document for a number of reasons, and are kind of happy with current format as its navigable.
1) Number of modules available versus used in a given firmware/template
2) Default framework linking and settings
3) Which modules are high-speed versus high-accuracy
4) Assessing meter capacity for custom frameworks
@Arneil_Dalope @Anonymous user  anything to add?
Regards Richard
Arneil_Dalope
Arneil_Dalope
Mentor
Posted: ‎2020-11-09 04:04 PM
16353
Hi Charles,
I would like to add to Richard's list numbers 5-7.
5) Total Processing power used for every default firmware/template
6) Processing power used of a module
7) Module Handle
Arneil
Charles_Murison
Champion
Posted: ‎2020-11-10 02:42 PM
16348
Hello @Arneil_Dalope  and @richard_schwass ,
Would you be able to expand on what you would expect to see for point 2, possibly even an example? Note that at this time a graphical representation of a framework is unlikely, maybe something in the future but at this time outside my scope.
I am not sure I understand point 4.
5,6,7 while great suggestions may take a bit longer to get rolled into the new output.
Charles
richard_schwass
richard_schwass
Explorer
Posted: ‎2020-11-10 02:50 PM
Hi Charles,
Have a good play with the current chm... if you expand "Detailed Framework Info" then this is what I mean.
Yut
Yut
Leader
Posted: ‎2020-11-16 10:50 PM
16332
I found that the ION8800C model is not up to date in the reference data recorder module is 2 but the latest model we ordered has 4 data recorders.
Charles_Murison
Champion
Posted: ‎2020-11-17 08:44 AM
16329
Hello Yut
Thank you for brining this to my attention, however at this time I am focusing on the HEP products (ION9000, PM8000,ION7400) for the new tool. There is a possibility of increasing the scope to other products in the future.
Charles
Charles_Murison
Champion
5
16313
Hello All,
Summary page
Module counts
Data recorder
@Grant_IPACS
@Arneil_Dalope
@richard_schwass
@kyle_coveart
Grant_IPACS
Grant_IPACS
Mentor
Posted: ‎2020-11-26 02:27 AM
looking good...keep up the good work @Charles_Murison
Regards
Grant
Arneil_Dalope
Arneil_Dalope
Mentor
Posted: ‎2021-08-12 04:21 PM
15387
Hi Charles,
Just want to bring this topic up again.
Not sure if you end up with the spreadsheet. If you already have, can you send a copy please?
Thanks.
Arneil
@Charles_Murison
Charles_Murison
Champion
Posted: ‎2021-08-17 02:47 PM
2
15359
Hello @Arneil_Dalope,
Still working on this tool to create the spreadsheet(s). I had to replace my laptop and still having little gremlins getting the tool back up and running. Still working on this when I get the time.
Charles
JamesAZZO
JamesAZZO
Leader
Posted: ‎2022-01-18 04:52 PM
14308
@Charles_Murison - is there a release of this or a new ION Device Template Reference chm file? We need something with the ION9000 / 9000T in it for our planning and designs.
Charles_Murison
Champion
Posted: ‎2022-01-19 08:56 AM
Hello @JamesAZZO ,
The .chm format no longer available. I will contact you about what information you are looking for.
Charles
richard_schwass
richard_schwass
Explorer
Posted: ‎2023-02-07 03:10 PM
12458
Hi Charles, we also need this solved, really love the old chm, what is the reason it was killed?
I am now after module info on the upcoming releases of tiered PM8000/ION7400 "L" "A" variants etc...
Can you provide this? At least in xlsx format? Regards Richard
Charles_Murison
Champion
Posted: ‎2023-02-07 03:59 PM . Last Modified: ‎2023-02-07 04:04 PM
12455
Hello Richard,
I few reasons, the tool used to build this had become mostly manual process on a computer no longer supported. Microsoft has also dropped support for the .chm file type. I am working on a side project to possibly make something like but, A) different format and B) possibly different information. This is really still early stage. What kind of information would you want to be able to find?
regards,
Charles
richard_schwass
richard_schwass
Explorer
Posted: ‎2023-02-14 03:20 PM
12373
Hi Charles, I understand the difficulties you have. Trouble is that this info is something that all EcoXperts working with ION frameworks rely on. I really need ASAP the module counts for the upcoming revised version of PM8000 series with the light and advanced versions. This should be counts by module and how many are used by the default template.
Beyond that the full document should have all the ION metering by template version showing counts and also module speed etc...
I hope this can be prioritise more than it has for the last few years.
If you can source me the PM8000 info that would be much appreciated as I have to submit a tender and need to see if this range can accommodate the frameworks required first.
Sanjeet_Sahota
Sanjeet_Sahota Mentor
Mentor
Posted: ‎2023-02-14 03:21 PM
Hi @richard_schwass
I will reach out to you directly on this topic and share the module counts.
Thanks!
Sanjeet
Thabang333
Thabang333
Explorer
Posted: ‎2025-05-21 05:24 AM
7216
Hi
I need help with billing module
Charles_Murison
Champion
Posted: ‎2025-05-21 09:22 AM
7198
Hello @Thabang333 ,
This topic is not a good place to ask this question. The module counts for the PM8000, ION7400 and ION9000 meters are now included in the firmware file zip file.
Likely you are asking about the Power Monitoring Expert (PME) Billing module. This forum is not the place to ask this.
Charles
sesa453448_brid
sesa453448_brid Explorer
Explorer
Posted: ‎2025-07-15 08:53 AM
5502
Hi  @Charles_Murison
Just following up, have you had a chance to build a new version?
Charles_Murison
Champion
Posted: ‎2025-07-15 09:06 AM
5501
Hello @sesa453448_brid,
The .chm file format is no longer supported and will no longer be updated. The firmware team is now including metering information inside the firmware .zip file including the modules supported for different feature sets.
Charles
sesa453448_brid
Explorer
Posted: ‎2025-07-15 09:18 AM
Thanks Charles, appreciated 🙂
CamboHeath
CamboHeath
Contributor
Posted: ‎2025-08-04 08:44 PM
5279
Hi Charles, I am after the module counts for the ION8650 meter Firmware 4.4.1 released in 2021
I note the .chm (which is no longer supported) only goes up to 4.1.1 so does not contain this information. The firmware .zip file does not have this information either, like for the PM8000, ION7400 and ION9000 meters.
Can you please advise where this information is available?
Charles_Murison
Champion
Posted: ‎2025-08-04 10:35 PM
Hello @CamboHeath ,
There is no document with that information as far as I know. If you really need that information please contact your local technical support and start a case. If support does not help, please let me know the case number.
Charles
eric.langford
eric.langford Explorer
Explorer
Posted: ‎2025-10-09 10:21 AM
4667
Thanks.  Found the module info in the .zip file as advertised.
But...(in case anyone was wondering) I still like the old .chm file ...
Thanks again.
Charles_Murison
Champion
Posted: ‎2025-10-09 03:09 PM
Hello eric,
I agree that .chm file is a great format, sadly the format is no longer supported by Microsoft so there are less and less tools that can make .chm files and some IT rules can even block opening ,chm files.
Charles
