How can I configure PM8000 using ION Setup?
Metering & Power Quality
  • EcoStruxure Power & Grid
  • How can I configure PM8000 using ION Setup?
Charles_Murison
Picard Charles_Murison Picard
525
Mehran_Mehrnia
Admiral Mehran_Mehrnia Admiral
138
Ramasamy_N
Captain Ramasamy_N Captain
115
Anonymous user
Not applicable
Posted: ‎2015-05-20 06:37 PM . Last Modified: ‎2020-04-22 01:29 AM
2342
Hi, All.
I heard, ION Setup is supported PM8000.
But when I connect device using ION Setup, occurred an error.
So I did try to find device template in below path.
<C:\Program Files (x86)\Schneider Electric\ION Setup>
But there was not exist pm8000's file.
Is it released a new version?
  • ION Setup
sesa42108_bridg
Ensign sesa42108_bridg Ensign
Posted: ‎2015-07-29 11:12 AM
2149
Were you ever able to connect with the PM8000? I did for the first time yesterday using ION Setup version 3.0.15205.01.  I had to create a site first for the device, then add a meter and choose the 8000 meter, then put in the IP, and I think it was defaulted to port 7700.  It does work.
Replies 3
Anonymous user
Not applicable
Posted: ‎2015-05-21 12:39 PM
It sounds like you need the newest version of ION Setup.  It is FREE and can be downloaded here:     https://powersolutionscommunity.schneider-electric.com/thread/5703.    This should take care of this issue.
sesa42108_bridg
2150
Anonymous user
Not applicable
Posted: ‎2015-08-02 07:09 PM
Where is the ION Setup 3.0 Ver.15205.01?
I can't find this version.
