Continue
  • My Subscriptions
  • Events
Help to build a custom display in PM8000 showing MWh instead of KWh
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Help to build a custom display in PM8000 showing MWh instead of KWh
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
Yarom
Yarom Troubleshooter
Troubleshooter
Posted: ‎2025-06-23 12:14 AM
1186
I saw another post that this is one of the ways to answer to the question.
I am learning to be main support locally for the PM8000. I am discovering slowly much, but usually when specific requests come in. I have solved several requests by manipulation within ION Setup.
This application is a little more complicated because I cannot simulate.  The end user is National Electric company, at one of the powerstations.  They notice that the rollover at 9,999,999kWh.  They would like to see MWh on display and Modbus register.
I read the note about resolution in Wikepedia and aware of the issues.
https://en.wikipedia.org/wiki/Single-precision_floating-point_format
The precision at the level of energy at the power plant is not so important. What we are looking to do is have a matching value of HMI display and modbus register value (displayed on end user BMS/SCADA).
Can someone guide me on this, direct me to the material required in ION setup?
Yarom
  • ION Setup
  • PM8000
RobGraham
RobGraham Champion
Champion
Posted: ‎2025-06-23 06:16 AM
1
1175
This will require quite a bit of ION programming, but the instructions are laid out here:  https://www.se.com/us/en/faqs/FA203886/.  For energy values, I think you will have to go with Option 2 there.
To get the energy values output to Modbus correctly, you will need to relink the inputs on Data Mapping Egy 1 to the scaled measurements created above.
Be sure you test this thoroughly--I've never modified these inputs myself.
RobGraham
RobGraham Champion
Champion
1
1175
Charles_Murison
Champion
Posted: ‎2025-06-23 09:00 AM
Hello @Yarom,
Note that the front panel display cannot change the units displayed in the default screens. The FAQ is still a good starting point.
Charles
