Continue
  • My Subscriptions
  • Events
EM2357 energy reset
Metering & Power Quality
  • EcoStruxure Power & Grid
  • EM2357 energy reset
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
psit
psit
Explorer
Posted: ‎2025-06-13 05:08 PM
2459
EM2357 energy reset
hello,
need expert's help how to clear accumulated or partial energy value(delivered, received) in meter EM2357.
BR
psit
  • Did you know
Ramasamy_N
Ramasamy_N Champion
Champion
Posted: ‎2025-06-24 08:59 AM
Hi @psit @Jesus_Diaz
Please follow this procedure to clear the energy.
There is a special code which is not in the address list, you need to send message to meter via Modbus tool by following the below steps.
  1. Use a serial port tool (e.g. sscom) and configure the communication paramters as: Baud rate 19200, 8, Even, 1
  2. Obtain CRC of data frame. CRC16 can be obtained through the following website: http://bbs.rkckth.com/home/crc.html. Copy:” [Slave id] 0E A9 A0 55 55 55 55 55 55 55 55”, click calculate, and the value in box 2 is the CRC16 value. For example, for the meter with slave id 03, the data frame would be: 03 0E A9 A0 55 55 55 55 55 55 55 55 44 F8
  3. Input the data frame in the serial port tool
  4. Check the HEX display and HEX sending
  5. Click "Send"
  6. If the meter responses with data, then energy data has been cleared successfully
Ramasamy N
sscom51.zip
Jesus_Diaz
Jesus_Diaz Leader
Leader
Posted: ‎2025-06-18 03:51 PM
2440
Hi @Ramasamy_N @rohith-s,
Do you have information about this?
rohith-s
rohith-s Troubleshooter
Troubleshooter
Posted: ‎2025-06-23 10:19 PM
2393
Hello @Jesus_Diaz ,
I checked with China Support team, Energy clearing option is not available in EM2357.
I have attached the register map details of EM2357 model, you can refer to the same.
EM2357通讯手册V1.0.xls
Ramasamy_N
Ramasamy_N Champion
Champion
  5. Click "Send"
Ramasamy N
sscom51.zip
